307 Regal said:TURNA said:As well as a lock up kit for your trans.
Why is this?
The Electric Q-jet depending on the year car and where it was built effect the trans lock up.
Why is this?
Minion1186 said:with overdrive 2004r's the tcc system is hooked to the computer. Taking the computer away takes the ttc and overdrive of the trans away, the cure for this when removing the computer is to get a tcc lockup kit.
pontiacgp said:"3) The EGR valve. Technically you don't NEED it, but the computer is calibrated for use with EGR, so keep it on or you'll get part throttle pinging."
the EGR allows exhaust to re-enter the combustion chamber which reduces the cylinder temperature...removing or disabling it creates higher cylinder temps which can cause the pre-ignition pinging. Also without it you'll have higher readings of NOx if your worried about emissions
Jeezycol said:does anything need to be capped off once you remove the vacuum lines?
Minion1186 said:I never had a decent 307 run "right", something was always amiss with them. My cutlass supreme had a slight missfire and my cutlass salon had a super lean condition, ran almost ok with a 442 dual snorkel on it but ran like sh*t with an open element air cleaner on it. I tried richening up the secondaries with different rods,a different hanger and grinding down the air valve door stop so the flaps open up 100 percent rather than 50. If it's not running right chuck the electric q jet,ccc distributor and dehose the engine bay. I would then grab a new remanned q jet or a good used one and put any olds HEI distributor in it from 1979 and down and it'll run a whole lot better. I have done this a couple times and from experience the 307s got a little more peppier as opposed to when the ccc junk was on it.
DoubleV said:pontiacgp said:"3) The EGR valve. Technically you don't NEED it, but the computer is calibrated for use with EGR, so keep it on or you'll get part throttle pinging."
If this was directed at me, I'm not sure why you posted this. I know how the EGR works and what it's purpose is. The ECM adds extra timing advance during the times the EGR is working. If you delete the EGR, the ECM will still apply extra timing advance during part throttle because it doesn't know the EGR valve is missing. This can cause pinging. This is why I said the computer is calibrated for use with EGR.
pontiacgp said:DoubleV said:pontiacgp said:"3) The EGR valve. Technically you don't NEED it, but the computer is calibrated for use with EGR, so keep it on or you'll get part throttle pinging."
I was pointing out another issue with removing the egr....that is why I posted it...![]()
DoubleV said:Gotcha. I thought you were implying my quote was BS since I didn't really make any mention of how the EGR works.
