I do not see any benefit to boxing a upper control arm. lowers get boxed because on hard launch they can bend having to move the entire weight of the car but uppers get pulled on so the only thing I ever see is people welding thick washers around the frame bolt holes to avoid the frame hole becoming egg shaped from the constant pulling. Having a roto joint on the uppers is a real good idea.[/quote]
This is true! Replacing a stock upper arm with an adjustable one (with a "roto" type joint) will let you adjust the axle to center it with the frame and to adjust pinion angle.
Doug
Doug
