I didn't realize you're at 10-12 psi. Correct me if I'm wrong, this is a 500+ cube Cadillac at 10-12 psi of boost? So a 400hp+ motor plus another 80%, so 700+ HP?
I think the Sniper 650 system will get that done with a small increase in FP. But if you're looking at a multiport system, then I agree - you'll need a custom modified steel stock intake for 8 injectors, runners, TB, and fuel lines/system.
Inj- Deka 80's $400, runners - $200, TB - $200, fuel system $600 (minimum) and ECU + wideband. So $1200 + ECU and wideband. Yup I agree the multiport system will be ALOT more than $1200.
So what are you using for a carb now? A CSU or did you modify it to handle boost? If you say that you modified it, then I would stick with it if you have that skill set - way cheaper and a blowthrough carb is better than meth injection for detonation resistance.
Please elaborate
