I'd have more respect for myself if I taped it to my head.
*looks at aem box on the shelf*
Tuning a carb with an AFR and a vacuum gauge is great. It's quick and easy and it's cool to see how the carb changes really impact the AFR numbers and how a little tuning will go a long way.
The Holley Sniper EFI is a whole different animal. Mine took about 8 hours to install including the Hyperspark distributor new sending unit and fuel pump. Once everything was wired up I turned the key, waited for the pump to prime and it fired right up and settled into a nice high idle. Adjust the idle down, adjust the afr targets and it runs like a dream. I can make impactful changes on the fly. You can then upload to a laptop and using the free software tune every aspect of the fuel and ignition system. It's pretty impressive for the money.
If it can make my crate Goodwrench 350 with the too big cam and stock heads run as well as it does, it should work wonders for a well built engine.
tape the phone to your head....or get one of these...
is the sweet stache included?
