Dad bought this 73 IH 1110 pickup with a 345 V8 back in '03 I think. Probably the most rust free international out there. Spent most of its time in Texas. Originally it had some Ford plastic hub caps over some steel wheels and was in decent shape. At one point sombody did a poor job painting it lime green... Why? It was orginally a nice two tone blue with a yellow roof. Finally got enough time and I feel comfortable painting it now so its time to go back to the original paint scheme.
In 05 Dad welded in a early 90's Dodge IFS front end. Got rid of the stock solid axle drum brake front end. Changed seats twice, installed a vintage air AC system, changed wheels, ect.
3 years ago the motor started to run crappy. Ran rough, missed, ticked BAD. Put it in storage. Built the cutlass, built the firebird, fixed a jeep.
And now to the current time. Pulled the motor to discover the ticking was from the exhaust manifold gaskets being entirely shot. Its known that IH's have cam bearing issues, the bearings de-laminate and the cam journals dump all the oil. Top end looses all oil pressure. That happened on this motor. Also, the bearings got loose and the cam gears jumped a tooth or two. (factory gear drive) Reason why the motor ran like crap. Put in new bearings and a cam, re-ringed the pistons, honed the block. Moved on to the body, pulled the box off, fixing rust (its an IH, it rusts like nuts) and cleaning the interior up.
