mickey-d said:. I bought some two weeks ago and it was $2.77 per gallon. Also, contrary to what people say, Ethanol is NOT CORROSIVE! Methanol, Alcohol is corrosive. Two completely different types of fuel. Ethanol, E85 is CORN BASED, they make whiskey out of it, you could drink it, it's moonshine with some gasoline mixed in it. All natural ingredients. If you really want to know about the fuel, don't guess, check it out for yourself.
I know a little bit about alcohols :wink: ethanol is very corrosive. Certain metals react stronger with ethanol vs methanol, and in general alcohols vs water. The polarity of ethanol has something to do with its ability to solvate rubber/plastic worse than methanol (they're both bad) in seals designed for gasoline, they are about the same acidity. But you're correct when mixed with 15% gasoline its much less corrosive than methanol and water. Ethanol isn't going to cool your combustion temperatures more than cheaper water injection, for the simple fact that it burns. Wherever you found some of that info sounds to me like a sales pitch, think someone trying to sell you on something.
It aint cheap here, its about the same or more than premium gas and those places are few and far between, Then again the local gas station its 3.20 for 93/94 and everywhere else in the nation from what I hear 87 is more expensive than that. Houston has that oil thing goin on where we get cheap gas coming off the refineries on the south side.
