I just rebuilt an old 307. I was cranking it by hand and could hear the air escaping from the cylinders into the exhaust on what I believe to be the exhaust stroke. The only reason there is doubt that this is actually the exhaust stroke is I found that I was also getting air coming out in short quick bursts from the carb.
This was a budget build, and these heads were off of a 5yr old 350 gmperformance crate engine. So I'm thinking that I either set up the timing chain wrong, these heads aren't a direct swap (different valve placement, exhaust valve where intake valve should be??) or I've got some sticky valves.
What's the quickest check I can do without having to tear this thing apart again?
