90' Fbody Steering box - is it worth it?
autonaut
209
31
Hi Guys.
I've been reading up on the fbody steering box replacement today.
I have one in good condition in the shop, so do you think it is worth replacing?
My 87 El Camino has the stock steering box with about 3 turns from one end to the other.
The Fbody steering box is 2 3/4 turns from one end to the other.
I know bump steer could be an issue.
And i know the fbody steering box has internal stops and will limit my turning radius. I could swap the stock end cover from the stock steering box to the fbody one and then be able to turn left without decreased turning radius.
But still. 3 full turns vs. 2 3/4 turns. Is it worth it?
What do you think?
If you currently have a worn and/or leaky steering box, I say, go for it. It's a nice upgrade, you will feel a noticeable difference in the steering.
Do you plan to remove the stops in the F-body box? I have the Monte SS box in my car, which does not have the stops that decrease turning radius, in which the F-body close ratio box has.
There also is a modification to re-valve the PS pump for increased steering assist. However, I've never done it to mine.
The stock one is neither leaking nor worn. But going from 3 turns to 2 3/4 turns and as a minimum decrease turning radius when doing a right turn seems kindda foolish.
Unless that the steering feel is that much better in a Fbody box compared to the stock box.
What ratio steering box did you use for your swap?
And can one remove the internal stops? I did not know that.
My box is out of a ws6 trans am and is 2.25 turns lock to lock with tighter valving. Huge improvement over the granny pinkie turn box I had
Normally I wouldn't comment on this because steering feel is personal preference in my opinion. However, since I already went through this; if you order, lets say a steering gear for a Monte SS and you order a gear for an IROC Camaro, guess what? When they show up, if you ordered AC Delco, they'll be the same part number. ...
:arrow: :roll: :arrow: :shock: :arrow: :wink: :arrow:
I think the box that is in the car now has the same ratio as the f body box. The f body box turns 35º while the G body box is 39º. that is the reason for the difference in lock to lock. Jack, I think your thinking of the Z steering box.
Steve,
You're absolutely right. I was thinking about the IROC or GTA box. 😳 The standard F-body box is no different than a standard G-body 800 series box.
That's the same one I'm using. My car has yet to see the road, but I also have a 34mm f-body sway bar. It's been awhile since I've looked into any of this, but I think part of the reason I went with this box is to avoid tire rub on the sway bar. Once I mount my tires I can confirm that.
thats one reason i did to to avoid hitting my 36mm sway bar lol. i havent noticed any issues or noticed the little less turning radius at all honestly buit the extra tight valving is awesome but it was twitchy until i got used to it.
