Should I remove the Air/Smog Pump on my Olds 307?
michael_l_matthews
41
Houston TX
If so can anyone tell me what to do with the lines that coming to and from the pump?
DoubleV
2,147
408
83
Medina Ohio
The entire AIR system is garbage. If you don't have a visual inspection where you live, chuck the whole AIR crap into the trash. Your car will be alot easier to work on and look alot nicer too.
When you remove the steel tubes that are screwed into the heads, before you plug those holes with the proper sized pipe plugs, stick a screwdriver into each hole and wiggle it around a little. Pull out the screwdriver and you'll have a small 1" or so sized tube on the end. These stupid tubes protrude into your exhaust ports which hamper flow.
Peter
1,175
74
48
MA
id say no don't bother unless your doing an engine overhaul or engine swap. makes no difference to performance and looks only go so far with a 307
85CutlassSalonRyder
122
Dallas,Texas
I just recently done it myself. I've been wanting to do it for a while actually. It makes changing the valve cover gaskets a sh*t load easier! Hers's a few pics of how I plugged the holes myself...
