It's cheap and easy....there are two tooling holes in the lower lip of the rear crossmember that I used to install the stock sway bar links. You can use the stock parts to mount the bar to the axle. I have a 8.2 rear end so I had used a 3" u bolt from a muffle clamp. I had to slot the holes on the sway bar mount to use with 3" u bolt but if you have a 7.5" rear you can use the stock u bolt. The bar is too wide so the arms have to be pulled in 1.5" on each side. I heated the arms and straightened out the ends to pull them in. The bar sits a bit too far forward so I rotated the bar on the axle tube and then tightened the u bolts on the sway bar mount and installed the stock sway bar link.
