I,m finally working on a replacement for my bolt on fiberglass ground effects. I made samples from aluminum to decide on the profile as seen in low quality picture. They will widen the lower body to blend better with the 2010 camaro nose. The lower profile is the same as the camaro without ground effects & the upper profile will premenantly be attached to the body with probably 3-m 8115 adhesive to resemble many late model profiles. The lower part under the door will be one long section & will screw on to the door sill & the fenders & quarters, which will allow for repairs if & when needed.
The new profile willgive a much smoother look & make the vehicle look lower, should really look cool with air ride. You listening boatshoes? Making from 18 gauge steel, which i will get help from a sheetmetal shop I deal with at work.Will post better pics when I start with the real metal.The hardest area will be where the front door opens at the front fender. And I,m not 100% sure how to design the rear quarters yet.
I'm trying to make this a project that others can either copy or change to suit their tastes, will post specs later .Someone with decent fab skill can have the main profiles bent for them by a sheetmetal shop, do the cutting to length & fitting themselves, Have the welding done if they can't , & attach with structual adhesives & screws.
