That's the thing about Springs.
I can take the same set of 4 and put it in 10 different cars, and it will look different 10 times.
I just lowered the cutlass with 1 1/2” bmr drop springs in rear with bell tech spindles and uncut 5660 springs up front along with the obligatory bilstein shocks all around
Also threw in a 442 steering box
Point is I don’t really love how it sits , but I can’t put my finger on it
Tires too small ? 255 45 17
Needs to be lower ?
Needs more rake ?
What do you guys think ? Like the title says be critical! roast me and my car lol I can take it
What would you do to make it better looking? View attachment 222630 View attachment 222631
I tend to agree , I’ve been thinking a 275 50 17 for rear , I believe I have room or can make someIt's a great looking car.
If I want to be really picky. I think the front wheels and ride height are fine. It's a combination of the rear ride height and wheel/tire ratio that seems a bit off. Maybe just a bit more sidewall in the back. A 50 or 55 tire. That would give it just a bit more rake. Not sure if you have the clearance there or if you really would want to run staggered tires.
Again, that's just being really nit picky. I think it's a great looking car.
That looks sharp , you’ve only lowered that 1” ?Here's my '80 Malibu with Eibach 1" lowering springs, with a 1/2" spacer between the rear springs and the axle. 245/45R17 on the front, and 255/50R17 on the rear.
You're going to find that room close up really fast with that size. As mentioned mine is a 285/40-17, it's 1" from the inside of the wheel well and damn near flush with the fender lip. 17x9 wheel.I tend to agree , I’ve been thinking a 275 50 17 for rear , I believe I have room or can make some
What is your backspacing ?You're going to find that room close up really fast with that size. As mentioned mine is a 285/40-17, it's 1" from the inside of the wheel well and damn near flush with the fender lip. 17x9 wheel.
after looking at DWs , I see the issue. that squared off wheel well which puts a big empty hole in each corner, it's those ugly holes you need to pull attention away from. as others said, nothing really wrong with the stance, but definitely need to pull attention away from the holes. use different wheels, larger sidewalls, or some side-trim paint detail on the fendersMy backspacing is 4” rear and 4 3/4” front both 17x8
Wheels fit well the rear tires are about an inch and a quarter to fender lip
I am willing to roll fenders if necessary
17x9 with a 6.5" backspace, but I have a 9" at a custom width.What is your backspacing ?
