grounding your radiator
86 Salon
Mar 14, 2021
72
79
I put mine in place of drain. On Becool radiator it is on pass side bottom of tank. Wondering if it will hinder flow on outlet or deteriorate faster because it is in direct flow? 🤔
I don't see any way that it would hinder flow or deteriorate faster from flow. It's sacrificial from electrolysis, not flow. They will work anywhere in the cooling system. They can even be installed in the engine. I like it where I put it because I can see it by just opening the radiator cap.
84cutspreme
1,146
152
I wish my heater port was threaded…just hose nipple. I just assumed water flowing erodes anything it might expedite deterioration of anode. Either way I feel better with it in there
scarborough
309
66
I put one of those in my Griffin radiator for my 73 Buick. The radiator had a threaded hole for a heater hose fitting in the top of the right tank. I just put a reducer bushing in the hole so the anode would fit. It's been in 8 years and I would say that it's about 10% gone so it must be working. Good insurance.
thanks. I will install one those !
86 Salon
Mar 14, 2021
72
79
Is the nipple threaded into the manifold?
84cutspreme
1,146
152
