Which foam would this be?If anyone at home wants to attempt this, and needs any of the 1/4" foam retainer material, hit me up. I got plenty!![]()
The foam under the plastic bottom and the top of the canister. The carbon sits between them. After the bottom is cut off, and everything is removed, the top foam goes in first, then the carbon, then the other foam, the push in plastic retainer, then you glue the bottom ring back on.Which foam would this be?
