Gray Man, Inc.
The ribs are still tender but that's about the only lingering malady.
I wrastled the transmission swap on the Supervenza for a couple days. Its a ridiculous amount of work. My dad was pretty instrumental for about 3 hours in the middle.
The LKQ chimps had obviously F'd up several seals so I replaced as necessary.
Once I got it all back together, there's a 60 digit recalibration procedure. Fortunately, I have the factory software for that.
The fluid top-off proceedure is ridiculous. Like many modern transmissions, this has no dipstick. You warm it up to 185deg (which takes about 40-50 minutes) then fill or drain through the bottom of the pan. I got it all buttoned up and took it for a drive. It shifted perfectly so I parked it in the garage. The next morning I noticed a bunch of ATF under it.
Initially, I thought it was an axle seal. Once I got it apart, I found out that the yard chimps had poked a hole in the case. **** LKQ! I cleaned everything up and put 3 thick layers of epoxy over the hole.
After 3 layers, I called it good. I did about 1500 miles for work this week ( in a loaner Vibe), but when I got back I put it all back together. Surprise! Now I have about a dozen communication codes. None of the modules are being friends, so now I only have 2nd and reverse. It was 105 degrees and I'm a quitter. I'll dig deeper tomorrow. Hopefully it's just a bad ground or connection.
I thought Toyotas were supposed to be reliable?
  • Sad
I wrastled the transmission swap on the Supervenza for a couple days. Its a ridiculous amount of work. My dad was pretty instrumental for about 3 hours in the middle. View attachment 242755
Once I got it all back together, there's a 60 digit recalibration procedure. Fortunately, I have the factory software for that. View attachment 242756
Initially, I thought it was an axle seal. Once I got it apart, I found out that the yard chimps had poked a hole in the case. **** LKQ! I cleaned everything up and put 3 thick layers of epoxy over the hole.View attachment 242757View attachment 242758
You're a bigger man than me. Thats a lot of nonsense for a transmission R&R. Glad you are feeling better.
All joking aside that sort of stopped being a thing about 10 to 15 years ago, at least compared to the way it used to be.
Some are better than others, BUT they've had a lot of high profile failures more recently. The list is getting long between the Tacomas and 4runners, not to mention the testing/certification scandal and emissions cheating, among others....
I was mostly being dramatic. No manufacturer is without issue, but I'd still take a Toyota over most others as a whole. I could certainly tell you plenty of stories about some of the other manufacturers I've done work for.
I've got a couple other cars to work on today, then I'll get back on this Venza. Did rear brakes on my daughter's Forester yesterday afternoon. Wife's Venza needs rear wheel bearings and I need to change oil and replace a noisy cooling fan on the Vibe I borrowerd from my dad.
It's supposed to be 105-108 for the next few days and I'm just not looking forward to working in the shop. We're socked in with wildfire smoke right now and it seems to make it more humid, along with irritating your lungs after a few hours outside.
It's supposed to be 105-108 for the next few days and I'm just not looking forward to working in the shop. We're socked in with wildfire smoke right now and it seems to make it more humid, along with irritating your lungs after a few hours outside. View attachment 242772
Get palm fronds. If the women folk want to keep breaking cars and expect you to fix them, then can fan you while you wrench....
  • Useful
Really who's not cheating emissions? When the standards exceed the available technology they do what they have to.
Read up on just how bad the Toyota schemes were. It went beyond emissions. They even had third parties manipulate fuel injection manifolds to inflate false torque certification numbers. Pretty messed up.
Well, I might be over the hump...maybe. I went over all the connections and grounds and was still getting a U0101 TCM communication code. I went through the the diag tree in Toyota's manual (GTS+) and verified all the powers and grounds were present at the main connector at the transmission. I also ohm'd out the wiring between the TCM and ECM, no faults found. At some point during my testing I lost 2nd gear -- now only reverse.
The TCM on these is bolted directly to the transmission and the harness plugs into it. I attempted to resend the 60 digit calibration code and my laptop couldn't even communicate with it now. I swapped out for the original (to the car) TCM and powered it up, then cleared the code again. When I started it up. No lights came back on. Took it for a drive and it shifts fine. No pending codes and no leaks. Apparently, the "new" TCM must have been damaged in shipping and progressively shut down after the transmission install.
I'm going to keep it local for awhile until it earns my trust back. Most of my work outings are 1000+ miles, so I don't want to push my luck.
I've got a couple hundred local (taco run) miles on it now. So far, no leaks and it's behaving as it should. Now that everything is working okay, I'm reminded what a nice driving car it actually is.
Stay cool out there, gents.
