Took the car to Rock Falls yesterday for a test session. Trailered it as I now have access to a decent trailer and pickup and didn't want to mess with breaking at the track first time out on a new setup with a toddler at home.
Since I don't have a roll bar I'm limited to 11.50 for sick summer so I had to figure out how to slow it down and be a bit more consistent.
Put the lower boost pulley on and replaced the 4yr old Hoosier DR with some MT street R's
Pass 1: 3400rpm on the 2 step, 21 psi tires, tried to give it ~50% throttle and then go WOT when the clutch grabbed. Bogged off the line but 1.87 60ft, 11.68 at 124mph
Pass 2: 3400 on the 2 step again, 21psi in the tires, gave it 100% throttle at the line and spun and had to pedal. 11.66 at 124
Pass 3: 3400 again 20.4psi, tried to see if I could pedal it back to 50% throttle but it wasn't repeatable and it was like 30% and bogged hard, 2.16 60 ft and a 12 sec pass
Pass 4: my brain isn't capable of consistently getting the throttle open to the same % ever tone so I pulled the 2 step down to 2600 and went 100% on the throttle. It bogged but it felt smoother and consistent, 1.83 60 and an 11.70
Pass 5, put 3100 2 step and it 1.78 60 and an 11.54. it still bogs a bit, around 2600 rpm after the clutch grabs but it's enough to not totally kill the momentum so that's where I'll leave it for now.
So next month if I'm slow I can put a few 100 extra rpm in at the launch and if it's fast I'll take some out. It has 1.55 60ft with 4400 on the launch rpm so I've got a lot of variability to play with.
It trapped consistently and shifted good, fuel looked good and went down the track consistently.
Made 8-9 psi up top. Basically the only easy variable I have is launch rpm plus its kinder to the drive line and it's not going to have any issue hooking at the line at only 3000 rpm on the line so probably the best 'safe' option for 5 different tracks.
Cooper and his dad who now own the wagon were there, Cooper is 14 now so he was getting his Jr Street license.
Car is 3855 without me.
So with me in the car is 4040lb, with the trap speed it's probably 620 crank HP.
So my to do list for the next month
1. Fluid change
2. Install cupholders
3. Get some better method to adjust my front shocks
4. Get AC working
5. Get trailer wiring and a hitch figured out
Should be enough to keep me busy
