15" aftermarket wheels
druggles85
Pendejo
Oct 25, 2009
282
468
Exeter, NH
I don't want to be "that guy" asking what the largest tire I can fit with a 15" wheel is without knowing any other spec.
But I guess here I am kind of doing that. I have some 15" x 8.5" aluminum wheels with a 3.75" backspace. I want to run the widest tires I can get away with using.
I might prefer all four to be the same size but would definitely consider running two different sized tires .
Ribbedroof
4,903
7,005
Wellston, OK
It'll vary from carline to carline...Montes and Pontiacs have "rounder" wheelhouses than , say, Malibus or later Cutlass.
JAMCAR223
1,853
5,507
Houston, TX.
I never knew that...
druggles85
Pendejo
Oct 25, 2009
282
468
Exeter, NH
Well I tried a different set on the back with 245/60R15 tires. Think they'll be fine on the rear. Just don't know about the front with these wheels.
JAMCAR223
1,853
5,507
Houston, TX.
They will be fine on the rear, but seems like a lot of tire on the front. in my opinion...
9,614
12,683
The first set of rims I bought for my Monte were ARE 15" x 8" with 4" of BS and I ran 245/60 fronts with 275/60 rears, as stated there are a lot of variables when fitting rims even with the same models, ride height and condition of body mounts all come into play.
I do think with your 1/2" wider rim and 1/4" less BS you could have some fitment issues in the front.
druggles85
Pendejo
Oct 25, 2009
282
468
Exeter, NH
I'm not committed to that much tire on the front. I haven't even bought tires. I just picked up these wheels cheap and need them in my life
1,167
2,638
West Virginia
I like those on a Regal. I haven’t seen them on anything else other than the General.
