BUICK 1964 Skylark Coupe Project
Was this a factory stick car?
A GearVendors behind the M22 wouldn't suck. Having one behind the Toploader in the Galaxie makes the car.
For the cost of a M22 the 5 speed option might be a something to look at. But then T10's don't seem to be that bad in price for new units. I should dig out my '64-'72 Chevelle Hollander book. for some quick reference on a few general things that Specials shared.
I dig the idea of the manual
But honestly I can't recommend an original used Muncie or similar 4 speed based on my used t56 experience. A t56 is not a Muncie but it's a used trans that has a lot of parallels.
I don't save a Muncie is bad because of the non OD, but every OEM Muncie based trans is worn out. If it's rebuilt by a known builder it's almost the same price as a warrantied new TKX 5spd.
Local muncies are $1200-1800. They don't have shifters, bells, clutches, just the bare trans. I almost guarantee they need some light to medium repair and they are 50 years old at this time.
A new TKX is $2800 and it has a shifter.
Honestly I got a 97 t56 that shifted good for $500+a disassembled LS back in 2016, a great deal. It slowly wore out but didn't shift great last year. It got a rebuild to the tune of $1300 in parts, and mine took relatively little in unexpected components as only the main shaft and one gear were worn. If I paid someone to rebuild it, maybe $300 in labor and actually paid normal retail for the trans of $1000 I'd be in the trans $2600. A brand new magnum F t56 is $3400. I saved $800 yeah, but if I had any more parts worn out it would have been the same or less to go brand new.
The issue is service parts for manuals are expensive, essentially every trans is beat to snot, and the new warrantied, clean trans to your door is almost the same price and better with an OD that unless you are doing a numbers matching resto or already have a core that's known you buy yourself into a condition where you know its not full of metal shavings.
Well that definitely gives me something to think about. I was leaning towards a 4 speed for era-correctness and RAWK CRUSHER street-cred from the New Balance crowd at the car cruises but when you take the price into consideration, and new vs. used like 81cutlass pointed out, a TKX may be justifiable. That purchase is down the line a bit but you guys definitely make a good point.
It was originally an automatic.
Yeah, M22s get you within a few bucks of a TKX. You might be able to find a TKO 600 for a little less, if there's any left.
TKO600 shifts like hot garbage compared to TKX from what I hear. For a small difference in price there's absolutely no reason to go TKO.
Reactions: Streetbu
Well that definitely gives me something to think about. I was leaning towards a 4 speed for era-correctness and RAWK CRUSHER street-cred from the New Balance crowd at the car cruises but when you take the price into consideration, and new vs. used like @81cutlass pointed out, a TKX may be justifiable. That purchase is down the line a bit but you guys definitely make a good point.
Good chance Renicks may have the needed BOP bell housing at the top of the hill in the pile.
Any idea what ratio your current rearend is? BOPs tend to be taller than Chevys, generally speaking.
That would be very cool.
Being a V8 automatic car, it should have 2.78s from what I've read. I haven't confirmed that though.
Reactions: Texas82GP
