They make bolt in kits but since you are BOP it makes sense to piece everything together.
www.speedwaymotors.com
My recommendations:
Find an OEM BOP bell for $100, steel is cool and all but you aren't running 11's or faster where you risk amputation if the flywheel blows up and the buicks don't rev so low risk
Find a Buick stick flywheel, probably the hardest part
Buy a clutch from Fabbot (he makes the AR5 to LS adapters locally to me), he has a private line of clutches that are sourced from the same place Monster gets their stuff at a much less markup, I think he offers a 10 spline replacement
Go with a hydraulic TOB from Howe or similar to remove the need or wore out linkages
Chevy TREMEC TKX Driveline Kit, Clutch/Flywheel/Bellhousing
My recommendations:
