I feel your pain I've had days like thatEver had so many things go wrong that it is funny? Well I pulled the pan on the 350 going back in the 70S, motor fell and broke the weld on the inside nut on the drain plug. I had a tick, actually probably an exhaust leakso I went to an adjustable valve train and over tightened the valves. Well #7 actually broke a push rod, so I went back to the factory non adjustable valve train. I inspected all the cam lobes and lifters. None were flat, hardest lifter to pull was from #7. Still not concave and there was still a lobe left. Also #7 and #8 were down to 110 psi, all the rest were 150 to 152 psi. I did gain back 10 to 15 psi with Kleenflo Combustion Chamber cleaner. Here is what I found. View attachment 139908
I'm not off either. And I'm exposed to biohazards lucky meClutch, I have had your luck lately. I have the one job in these times that I will never get free time off, fuel truck driver.
