The X pipe sounds OK, just this 70 must have a lot less padding under it than my 88 Brougham, just loud and droning. It had an air lock somewhere at that time, gauge wasn't moving and with no working tach, I must have ran the carb out of fuel, it may be pulling 5000+ rpm. A questionable line to carb and a fuel filter that isn't new, both will hopefully fix the issue. I just assumed the worst with the rad pressuring up. I just gambled reusing the thinner .028" head gaskets, not paying $100 US EACH for Olds .027" thick head gaskets on a temporary motor. I need to buy a rad pressure tester, it would eliminate the guess work. This carb is acting lean at idle, it should be the opposite, will spend some time on it. The slow cranking also made me jump to the conclusion it was filling the cylinders with antifreeze. If it was, it would probably be blowing the rad cap off on every run. I need this car running right for spring, I work 12 hour days, 6 days a week for a month straight.
