I finally tackled the project I have been dreading for a while. Both corners of the quarter windows were rotted back at the pointy part, right were normal tools really don't fit or are in the wrong position even if you get them in there. Out came the dremel, 90* die grinder, die grinder, and files.
Cut out the bad
Fabbed up a couple pieces
And Voila!
That sequence took hours of grinding, fitting, grinding, fitting, etc. I am usually all about metal work but this was not fun. Luckily the passenger side isn't quite as bad but I hope to knock it out tomorrow.
Cut out the bad
And Voila!
