1980 Cutlass project from Finland
Oh, okay cool thanks 🙂
Forgot to put some photos with new wheel caps 🙂 Also changed the tank sending unit.
Shitty photos, but you guys get the idea 🙂
Changed the lower bearing of the steering shaft. The car is getting better and better at cornering 😉
I just got the bearing kit from kirbans, gets rid of the plastic" bearing",
Actually mines from Jeep, so there is a real bearing inside that white "bearing". It fits right in, and here in Finland you can't buy anywhere that original part that GM used. Doesnt effect anything because as I said those Jeep steering bearings are easy to find 🙂
Modified trans crossmember today, for the double exhaust. Couple of pics:
No I can lift the exhaust nearly 2 inches. Im going to modify it when I get those headers 🙂 My current headers go superlow, and leak everywhere, theyre pretty discusting :puke: 😀
How is the transmission crossmember attached to the frame of the car? I have those two rubber bushings and then bolts tightening it up, but my friend said that theyre shouldn't be those bushings at all?
The rubber pads, or bushings on the X-member, look like something that was added on. I know mine didn't have them, and some cars did, but they were a thin piece of rubber between the frame and X-member.
I left those rubber pads away for now.
I think modifiaing that crossmember is going to make hell of a difference when I get those headers in place 8)
