80ELCAMINOFLAKE said:Son asleep!!!!Sun in his face too...hahahahhaha my little man...
80ELCAMINOFLAKE said:Lmao...Mel to do have a bigger wagon but forgot to take it with us...and I only wanted to spend $20 on a dayum wagon..I knew what going to fall asleep on me...but we had fun...
So got quotes yesterday to run pipe from flowmaster out and to connect my tips..fools wanted to charge me 120plus++
I think that's too much...I'm going to hold off and just keep on looking around until I find the right spot...n e one know a good muffler shop local;?
richp85elco said:it is pretty tricky doing the bends to go over the axels, they do alot of test fitting and going back to the bender but drive down avalon and find someone that will do it for $100 the deeper into la the cheaperor just go to the same shop and tell them you found another shop that will do it for 100 but there closer so you would rather go there, it always works 8)
With a little work it should be doable and bad *ss80ELCAMINOFLAKE said:Want to start working on my speedo and tach and fuel autometer procomp set up...and found this link...u think its going to be an easy task?
Went to home depot today and got some sheet metal...im going to need to find another gauge cluster so that i can use mine as a tester....looking around...
http://gbodyforum.com/viewtopic.php?t=4166
Dave V said:With a little work it should be doable and bad *ss80ELCAMINOFLAKE said:Want to start working on my speedo and tach and fuel autometer procomp set up...and found this link...u think its going to be an easy task?
