MALIBU 1980 Malibu 500 Cadillac
Streetbu
Know it all, that doesn't
3,745
11,619
Central NY
Back in the early 90's I was at the local muffler shop and the mechanic was pulling out a 1 ton 4x4 Chevy pickup. When he started it, the starter sounded different than a Chevy starter. I asked what was in it. It was a 500 Caddy. Guy that owned it was there and just had duals put on it. Swore up and down that the truck would get better gas mileage and tow better with it than a SBC or BBC.
Awesome build!
8,827
7,783
Awesome build!
Doesn't surprise me in the least. In my 78 1/2 ton with 2.76 gears, I had a stock Vin Y Olds 307 out perform two stock sbc 350's in every way, including mileage. An Olds 350 was even better. The sbc, just like LS, except the new Gen 5 motors are terrible truck motors, super soft down low. I argued with one guy on ROP of all places, how my 94 Olds 350 powered Z71 without a proper tune seriously out performed indentical drivetrain and gearing stock 5.3 LS trucks, idle to 4000 rpm. With a 454 TBI, it was even more of an annihilation down low and matched the LS up top, when it ran right. Of course he also endlessly defended how strong the 700R4/4L60-70E was as well😂. A Cad 500 in a square body would be amazing, power down low, no need for peanut ports to make low end torque.
1,167
2,638
West Virginia
I don't really get the full thump from the picture. Maybe a video would be better
While frying tires
At 5500 rpm
5500 with a 4.3" stroke? Are you kidding? ;)
500/600
1,167
2,638
West Virginia
Okay, 6500.
Now you're just talkin crazy. Seriously though, I'm figuring 6000 seems like a nice round number.
I can tell that you won't stop until you get a burnout video.
1,167
2,638
West Virginia
Just messin' with ya. ;) I have a 6k chip in the Olds; if it can breathe and has a light rotating mass, you're good.
The cam is good for 2400-5900 and the heads will support it easy. I’ll keep the 6000 chip in the MSD.
1,167
2,638
West Virginia
I just got the TH400 back together. I had it laying around since I put a Super T10 in my Skylark in 2002. Here are the mods.
1) Sonnax anti walk rear bushing
2) Sonnax rear roller bearing conversion set at 0.009”
3) Planetary shim kit set at 0.007”
4) Kevlar low reverse band
5) Four clutch Alto red intermediate with Kolene plates set to 0.035”
6) Replaced steel intermediate piston and plastic spring cup with aluminum piston and extra springs
7) 0.106” intermediate retainer ring
8) 5 clutch direct drum with Alto red and Kolene, set to 0.045” with dual feed mod and 34 element sprag
9) 5 clutch forward drum with Alto red and Kolene, set to 0.045” with ATI input shaft
10) forward clearance set to 0.012”
11) pump modified with converter restrictor and high 185psi relief spring
12) B&M/Transgo shift kit
13) stainless screen filter
14) Alto red direct band
15) direct band piston modification
16) adjustable modulator
17) B&M high rpm governor kit
18) all new bushings and seals
19) TCI 9.5” 2500rpm converter
20) SFI flexplate
21) Finned aluminum pan
8,827
7,783
Nice, showing clearances as well. Do you use a bottom feed filter, aren't the factory TH400 top feed like the 2004R?
