http://store.stepvanparts.com/GAS-TANK- ... -81960.HTM
for the top of the tank I use #90 roofing felt
pontiacgp said:http://store.stepvanparts.com/GAS-TANK-RUBBER-INSULATION-81960.HTM
motorheadmike said:Does anyone know of any clever stereo installations in these wagons? I am looking for some ideas...
liquidh8 said:motorheadmike said:Does anyone know of any clever stereo installations in these wagons? I am looking for some ideas...
Not sure what you mean by clever? I had an over the top install in my Malibu wagon, glass doorpanels, massive amps/subs, etc.
The wiper stank w/delay and cruise really aren't that bad. Since you have the donor car, you can easily see what needs to be changed. I did the same thing in all my older than 82 G-bodies.
Longroof79 said:Having the donor car will make converting your wiper stalk easy. You will need to convert to a later type wiper motor to correspond with the late type switch. ...and also make sure if you're using a delay wiper motor, make sure the switch is also the delay type.
You'll either need the pigtails from the bulkhead to the wiper motor, and the small pigtail from the later style column going to the wiper switch.
motorheadmike said:liquidh8 said:motorheadmike said:Does anyone know of any clever stereo installations in these wagons? I am looking for some ideas...
