kuruption109 said:good work skip foose. INSPIRATION! 8)
x2 yeah thats coming out nice!
already have something easy in mind, drilling a hole in an lbracket and cutting a slot into it, like the end of the piece in the pic you posted... saw that in one of the links in my earlier posts, but i wanna try to clean it up a bit... i dont really care about the ebrake, but i might as well have everything working...pontiacgp said:this is the OEM bracket for the ebrake....they look easy to fab if you can't find them..
sometimes the primer helps, I didnt used primer, but I painted the stuff initially, then sanded it down lightly, then repainted. you can use the high temp primer, then wetsand it down, then paint, may stick better in long run. I did have slight adhesion issue before i sanded it down and painted. next thing i woulda done was just powder the stuff, since my powder coater doesnt charge me much for stuff like this, but wanted to make this as cost friendly a thread as possible...redboy504 said:I got my rotors, caliper brackets and backing plates painted black. My daughter says they look good. I put them all in the sand blaster then cleaned them up with degreaser before painting. Everything looks good, but I still dont know what color to paint the calipers I may go with the aluminum color. One more question though. Should I have used primer beore painting? it all looks pretty good without it. I probably wouldn't have had to use so much paint if I had.
LSCustoms said:once i set it all up under the dash in the car, i will be running all new line, etc
