Next step is installing a 8.5 - 3.73 posi rearend. That will help a lot on acceleration and still be freeway-friendly with the overdrive transmission!
So about the 8.5 diff, I'll need to re-install LS1 caliper brackets, because the previous guy (from whom I bought the diff) had mistakenly installed the brackets "in front" of the differential shaft. Those brackets are really neat, well installed, and mounting the caliper clears the disk alright -- so I'm using these old brackets as a template to create the rear brackets. I'll have a shop machine a properly-sized rectangular 1-8" plate, with a 2.5" diameter hole, split in two. And then, some welding will happen.
