1985 Monte SS drag car build
DysonSS
145
281
Littleton NH
I have a chance to pick up a 8.8 from a 1986 mustang gt for $75 from a buddy at work. It has a posi but it’s weak and it has 2:73 gears, it also has no brake hardware. I’ve been researching the swap and depending on what you want it could get really pricy. I did find the trick chassis swap I/c brackets and control arms for $249 on their site and I already have double adjustable lowers with heim joints. Do you think it would be a good deal considering I would have to re-gear it, rebuild the posi and drill the axles?
lilbowtie
3,460
3,965
Canton Mi
That's for you to choose - I would personally buy a bolt in nine inch w/ axle package for around $700.00(new). You get to choose want ends you want on, axle splines, and bolt pattern. Nine inch pigs are cheap and for a drag car I'd run a spool. If your close to me I have one w/ 4.11 for $200.00. Plus you have a little more insurance over the 8.8
bracketchev1221
1,405
1,639
I think I would go with the bolt in 9” as well. I have been looking to see what would be best and I can’t beat the packages available.
DysonSS
145
281
Littleton NH
That’s what I was thinking as well after I did the math I was up to $600 not including brakes. The worst part is I had a stock pile of 9 inch parts 2 years ago, one with 3:50 gears and a posi. When I sold my cutlass I sold off all those parts. Now I’m kicking myself in the a**
Macguyver
SOUTHSIDE MACHINE PERFORMANCE
GBodyForum Sponsor
Mar 21, 2017
292
458
Have you considered the Explorer 8.8" swap?
https://gbodyforum.com/threads/southside-machine-performance-ford-explorer-8-8-swap-kit.70009/
DysonSS
145
281
Littleton NH
I got just about everything I need to put the car back together. It’s like Christmas in my garage 😂. The cage was backordered and it finally showed up today. I got my entire fuel system, poly body mounts, summit 3 way adjustable drag shocks, a tci fast gate shifter, sphon rear shock relocation brackets hopefully the 15x10’s clear them if not I’ll have to drill new holes for the shock mount(they were hitting the wheels) I also have the rear seat support which is tacked in place now. I ended up getting a set of 28 10.50 Mickey Thompson e/t drags, they were on sale at Jegs I ended up paying $168 a piece. I also scored some weld draglite 15x8 front runners with almost new 26 8.50 Mickey-Thompson sportsman tires for $200. I think I’m going to end up getting a bolt in 9” from quick performance I spoke with them and a bolt in rear with 4:10’s and a drag spool with disc brakes is $1650 shipped not bad. I’ll have to save up for that. Now I just need time. I can’t wait to get this beast going.
DysonSS
145
281
Littleton NH
Got a little bit of work done today finally. I got the trick springs and shocks mounted I ended up having to move the shock mount hole over. They still wouldn’t clear the wheels. Also the slicks are mounted.
gbodytoys
501
646
Detroit, MI
Have you been able to put together a package cheaper than the Quick Performance option?
