I think the A/C Box will go on first. Before I do I take the time to clean the duct work (since the dash is out).
There are (4) 7mm screws that hold it in by the window defrost ducts.
Once it's out I can take the two duct attachments on each side loose to help get to those hard to reach spots. I use some ArmorAll Cleaning Wipes to get the caked on dirt out.
All clean and ready for reassemble.
The main body is plastic welded together (like rivets, but melted plastic), and the flex hose is stapled to the plastic duct. I didn't feel like tearing that all apart, so it's as clean as I could get it.
Here it is all back together (minus a couple of screws that still need to go in).
The foam insulation was in great condition, so I left it alone.
It took six wipes to get the pieces clean. This was all inside and outside the duct work. It took some pressure wiping to get the crud off. I thought I could just push a swiffer through the ducts and be done. When the swiffer came out clean, but I could clearly see a layer of dirt on everything, i knew it needed to come out and get a deep cleaning. That's 33 years of built up grime!
With the duct work out, it should be easy to put the A/C Box in place.
Hutch
Hutch
