BUILD THREAD 1987 Olds 442 Project Build
Season 6 Bip GIF by Bachelor in Paradise
Any way on earth you can notch the light panel to clear the indentation?
You may lose the top center light but are they all connected together or can you "jumper" the center top lamp nodule? I'm no electrician or wire biter. Have NO earthly idea.
I do know that the manufacturer never actually tested them in an 81-83 lamp if they don't have an answer.
Reactions: Tony1968
Hope you get a fix! I love my digi-tails!
As do I, the only complaint I have is that I wish the turn would sweep to the side instead of up and down
I looked up the Digi-Tails and it says now the following:
Sequential Function:
Brake: inside to outside
Turn Signal: inside to outside sweep
In the Specs section of:
Maybe they changed it due to a great number of people wanting this?
I am going to order a set.
Yeah it is different for the Monte's, they are bigger which is all the more reason to me for it to go side to side. But this is how ours look
Reactions: Tony1968
Matt from Digi-Tails is trying to work the issue. More when it gets solved.
It does look like the center between two LED squares can be clearanced out to make room, just not sure if it's enough.
It seem that in the current climate, wait forever has become the norm for some things (my engine machining, digi-tails, lifters, gun parts.....)
Matt at Digi-Tails says the tech dept is still wrestling with my clearance issue (that's been a month)
My Morel lifters I ordered May 30 are still yet to be built (nation wide back order for Chevy lifters, so that's all they're making now)
A Glock Trigger Housing I ordered back on DEC 15 is STILL on nation wide backorder. It's an $8 part. A guy on ebay is selling it for $87 (he can pound sand!)
With the lock down last year, and now no employees, my machinist is so far behind who knows when that's getting done!
Mad Rainn Wilson GIF by T-Mobile
