Finally got all my parts together for the Serpentine Belt / R134A conversion.
The specialty brackets:
The factory brackets from a 91 S-10 Blazer 4.3L
The F**D 5.0 Serpentine Crank Pulley
Here's a list I compiled with the help of others who have done the conversion. HUGE thanks to 1bad79 for his help with pics and many of my questions about this.
They're still in boxes, as I'm a little ways off from installing them, so your results may vary 😏 :
Four Seasons Parts:
Orifice Tube – 38635 *Red* (95 Ford F-150 5.0)
Comp Hose – 56016 (92 Camaro 5.0)
Receiver Drier – 33183 (87 GN *Buy in store to check fitting clocking)
Compressor – 58937 (91 S-10 Blazer w/ 3 oz of R134a oil added)
Pressure Switch – 36674 (87 Cutlass R134a Conversion)
Spectra Premium:
Condenser – 7-4013 (87 Cutlass)
Dorman Parts:
Compressor Connector – 85143 (2 wire w/ Diode)
Gates:
PS Pump Seal Kit – 351160 (1960-2010)
PS Pressure Hose – 358090 (87 Cutlass/442 5.0)
AC Delco:
Idler Pulley - 38006 (91 S10 Blazer 4.3L V6)
Belt Tensioner - 38108 (91 S10 Blazer 4.3L V6)
Water Pump Pulley - 19418445 (91 S10 Blazer 4.3L V6)
Cardone:
Reverse Rotation Water Pump - 58-296 (82 Cutlass 4.3 V-6 Diesel)
Remy:
Alternator – 91324 (91 S10 Blazer 4.3L V6)
Echlin Ignition (NAPA):
SI to CS Alternator Harness Adapter – ECH EC82
Nostalgic AC Parts:
Inline High Side Charge Port – V401 (#6 5/8-18 Threads)
(This part was necessary because the Camaro Compressor Hose doesn't have a High Side Fitting like the G-Body does. This adapter will fit in between the hose and condenser.)
Again, this is just what I'm doing. At this point it's not quite proven, so buyer beware.
Hutch
Four Seasons Parts:
Spectra Premium:
Dorman Parts:
Gates:
AC Delco:
Cardone:
Remy:
Nostalgic AC Parts:
Hutch
