A good way to stop the "oil canning" is to tack weld spots on the flexing metal and immediately quench the spot with a wet rag, it will stiffen up your sheet metalFE3X CLONE said:Thanks guys.
Piddled around today doing a little powder coating. I ended up redoing my fender to core support braces. The big aluminum things I had were just sticking out too much. I also hadn't considered the fact that the heim joints at the core support end would hit the hood.
So I went to TSC and bought two 36" lengths of 3/4" metal tubing. Smashed the ends in my vise, put a couple of bends in them and bolted them up.
You can all see my finished air cleaner setup. I welded on a 1.5" lip to dress it up a bit.
Also finished my battery cover which I think turned out pretty decent.
Definitely helps clean up the engine bay visually. Kind of nice to have all the wiring slowly being tidied up and disappearing.
My neighbor stopped by tonight and we were discussing how to fix a few issues with the car. Namely my roof since I had a sunroof at one time and tried welding the hole closed a while back. The problem is that it warped the roof some and I've got a bit of oil canning going on. But I think we've figured out how we're going to fix that so I'm not going to be chopping the top to install T-tops.
Also we've hashed out a plan to fix my W-25 hood. The mounting points for the hinges on the hood had worked their way loose so I I'm going to have to cut into the hood and replace the steel inserts and refiberglass everything back in. Shouldn't be tough, just time consuming.
Bernhard said:Was there a factory brace that was cut when the factory put the sunroof in the car?
How much work would it be to re skin the roof with a hard top roof.
Are you going to use the factory fender braces or are they there for test fitting.
Bernhard said:I thought they were factory braces they look OEM very nice. I just read your earlier post that you are not using the adjustable braces and made these new ones. Are you now using the rubber upper rad hose?
