Okay I have an 86 el camino. I am in the process of doing an engine transplant and we removed all of the unused wires from the ECM harness. I know most don't approve of this but the harness was fried anyways from years of things melting etc. So my question is why won't my ECM still lockup my 200-4r's converter if that and the grounds are still remaining? Also if I left all of my a/c power etc. in and the ecm is still connected why won't it work as well. And my last question is if you convert to a non computer controlled dist. and carb do you lose use of your lockup without wiring a switch? If not then there has to be some way to get the computer to still control the lockup and a/c control only.
Thanks for your help, I just want to understand why it won't work not just that it won't work. Seems there should be a way.
