200 r4 to th400 swap
85RUTHLESS
n00b
May 13, 2014
when swapping out your 200 r4 for the th400 does the driveshaft u joint & yoke need to be changed also or can you use the same ujoint and just change the yoke? if you have to change both what ujoint do i use to match up with th400 yoke and and driveshaft
williamattop
455
53
Appleton WI
I believe you need the paired yolk for the short tail 400 and then get your shaft cut to size.
Should also be able to use (modify?) your existing crossmember.
chevy2480
1,245
6
38
williamstown nj 08094
U joint i am pretty sure is the same. Driveshaft is a different length and trans crossmember needs to be modified or swapped out and you need the correct slip yoke
Blake442
6,867
2,021
Minneapolis
Crossmember is the same for 200-4r and th-400. Use the 200-4r mount.
U-joint is different... The guy at the shop I took mine to just looked at it and knew what it needed.
Driveshaft will need to be cut approximately 1/2"-3/4".
Measure once it's together to confirm.
You'll need to run a vacuum line and install the electric kick-down switch.
It cost me about $100 to have mine cut and rebalanced.
