I've had several 301's, a 305, and a 307. I felt both the 305 and 307 had an extremely narrow power band that was useless for anything but highway speed fuel economy. I blamed the factory cams and rear end gearing. I went with the 301 and I have one right now in my Bonnewagon. It at least had a usable range from idle to 4000rpm. I know the limitations the 301 has regarding heads and intake- but as mentioned- fit the punishment to the crime. It will never be as good as a traditional Pontiac for power, but It is good on gas, meets emissions, and is pretty peppy with some decent gears. Mine is totally stock. I tried true dual exhaust and it changed nothing so I went back to a quiet single exhaust. I have a 4 barrel Q-jet, Saginaw 4 speed with 3:55 first gear, and 3:23 gears out back. It Moves! I am very happy driving it and it never has let me down. Here is an observation- if you have a 2 barrel version with crummy gears- leave it alone. Switching to a 4 barrel will not help. Change the gears first. A DualJet is the perfect carb for a stock 301 with highway gears and will outperform a Q-jet unless the gears are changed. But once you change gears- these motors will rev freely and surprise you. The Dual Jet is jetted well for a wide power range and unless you are changing other stuff like cams it is probably the best carb for a 301.
