Theres no need to try things that are obviously not correct. I'm curious where you're getting your numbers from TURNA? Did you just pick a number and say 'try this' and not put any real though into it?
Stock base timing with CCC was 20. Total is around 35ish. Most bump this up a couple degrees. Why should it now be much lower than this?
Does he still have the CCC system installed?
