350 ENGINE BUILD "PROJECT TUMMY TUCK "
Dropped off heads at the machine shop, they will be dipped, sand blasted, and pressure tested to see if there are any cracks in them...also new springs, rockers and valves..
i will post pics when i pick them up...
Also looking on ebay for a good 350 rebuild kit and they range any where from $230-250 total, there are two kind im interested in...Redline and Engine Tech Kits....i will choose one once im ready...I think one of these kits have (forged pistons) SKIP WHITE SELLS THEM..And skip white performance is good!!
Pistons & Rings: STD, .020, .030, .040, .060
Rod & Main Bearings: STD, .010, .020, .030
This Rebuild Kit will Include:
Ø Piston Set (KB-Silvolite)
Ø Piston Rings (Hastings)
Ø Rod Bearings (King)
Ø Main Bearings (King)
Ø Full Gasket Set
Ø Rear Main Seal & Valve Stem Seals
Ø Timing Set (Cloyes/Melling)
Ø Oil Pump (Melling)
Ø Camshaft Bearings
Ø Freeze Plugs
Ø Camshaft
Ø Lifters
Ø Full Gasket Set
Ø Camshaft Bearings
Ø Freeze Plugs
Ø Camshaft
Ø Lifters
Let me know if the kit is good and what you payed for it if they are this cheap i think i just might get me a 350 :mrgreen:
87chevyboy
Yes I will...its going to be a simple stock 350 build...well it is going to get bored 0.30...but keeping the crank,springs, rockers, all stock and new....but might go with different cam, so i would need to change the springs and lifters...but i will let you know
87chevyboy
i think im a pick up a sbc from a guy here in town and just put vortec heads on the mother fu**** :mrgreen: maybe a nice cam and thats it i think that would get me to 300 ponies and maybe some headers
Saint, take it slow do some more research before buying that kit, your going to get a cam and lifters you might not even want so you can save money there. Since you already have a good runnning engine save up and go with a Roller cam that way you dont have to worry about the oil you use because trust me it gets very expensive. And if you dont break it in right you can send metal all over the whole engine and ruin all the new parts you bought. For break in oil and for the first oil change after the break in I spent about $120 and I add about half a bottle of the cam additve every oil change. Thats already half way to a good roller cam that will last longer and you dont have to use expensive oil.
Yea looking at those kits they come with a cam and lifter's huh. I called the place were they had them for sale and they do sell the kit WithOut the cam and lifters, for like $40-$50 buck cheaper..so thats good and i will be paying about $190 shipped some where around there....so then i can choose a Cam of my choose.. Good looking out...
But can u tell me what kinda Roller cam im going to need for 350 bored 0.30 with the lifters? keeping same crank. if its not to much for u to search? mild cam...nothing crazy..nice clean chopping sound..
im not that smart yet bro, im still a youngster :rofl: I will try and help the best I can...
First what are you going to do with the heads? have them milled? ported? or if your just going to clean them up, see if the machine shop can give you the cumbustion chamber size for the heads your going to use. (Don't get springs or rockers yet they depend on the cam.)
once you know that. then you need to find out if your block is going to clean up with just a 0.30 over bore, and based on the cc's of the heads and the over bore we can help you pick the pistons you need and figure out your compression ratio.
One we find out your esimated C.R. then we can help you pick a good cam and the right springs, lifters, and rockers. So dont just buy anything yet all the parts depend on each other so do one thing at a time, you already started with the right first step
theres alot of people on here that know more about this stuff then me so hopefully more people will chime in, and we'll help you do it right 8)
I'll p.m you my number if you need any help hit me up, oh i'll have your dvd ready this weekend i just need to burn it now
NICE!!! great info....I hope this DvD will help me out...so that i dont have to ask so many questions on the forum..lmao
heads are just going to get cleaned and bored over 0.30
asking questions is how you learn, dont be shy :rofl: for every question you ask theres another million poeple that want to ask the same thing
so rather then make your decisions do you want to go roller (expensive) or flat tappet (cheap)? both will work fine you just have to make sure your really careful with the flat tappet and break it in right,
Might be a flat tappet or we will see as the build goes....i will forsure brake it in carefully...im going to take my time with the next build..
