374 Olds 350 stroker build
Yah, I will keep the studs as spares, what is less than $100 in this fortune I am spending. The 7/16" balls were $25, no loss. The Poly Locks, $50, again spares aren't so bad. I am missing a couple of 3/8" balls, $22 for a set. If I get the 3/8" to 7/16" studs and 3/8" balls is only $100 more🤷‍♂️.
More goodies.
Dial bore gauge
3/8" to 7/16" rocker arm studs, oil filter and 4 core rad pads and brackets.
Here is a list of the parts and costs for my build:
76 Oldsmobile 350 $100 US
330 forged crank came balanced with Speedpro 18cc dish forged pistons and stock rods, bought 10 years ago, sold the pistons and rods $300 US
Rusty 330 flex plate $35 US
Good stock balancer $0
Rebuilt Qjet, either this Everday Performance or the one built with Cliff Ruggles parts= $350 US
NIB Performer RPM, a steal now at $100 US
Rebuilt #6 heads with 2.07"/1.56" valves, bowls opened, new guides, basic valve job and machined for positive seals a steal at $325 USD
Bought used Comp Roller tip rocker arms with the necessary 7/16" rocker stud conversion $150 US
Optional Scorpion 1.72 SBF rocker arms $200 US
HS rocker which require rocker pad milling $400 US
Used Johnson Hy Lift Hydraulic roller lifters $100 US
Roller cam, springs, push rods, thrust bumper and Cloyes 9 way Billet timing set $1125 US
Mahle 4032 forged 4.100" pistons, pins and rings $625 US
Molnar DR forged with ARP 2000 bolts $615 US
ARP main studs $65 US
Cloyes cam bearings, Amazon clear out $8 US!
Rod and main bearings TBD
Canton Oil pan and pick up around $450 US
Flowkooler reverse flow water pump $100 US
Mahle gasket set $185 US
Felpro shim intake gaskets, composite won't fit without cutting the intake or heads $25 US
Engine paint $100 US
Accel 8.8 25 ohm race wires, no longer made $25 US
HEI Ignitor 3 module $100 US
Accel cap and rotor $20 US
Accel Brute Thunder coil $100 US
Adjustable vacuum advance and springs $30 US
AEM wideband $180
Davies Craig adjustable fan controller $110 US
Autocity 2 core 1 1/8" cores aluminum rad $300 US
Oldsmobile super compact mini starter $175 US
Sanderson headers still need finish work and coating $400 US
Good 2004R came with a 73 350 $325 USD
CK .550" boost valves and spool valve $105 US
CK improved GN Billet Servo $130 US
Good used TH2004R deep aluminum pan $140 US
Bore and hone the block to 4.100" TBD
Clean up mill on the deck TBD
Install Cam bearings TBD
Align hone the mains TBD
Grind the crank to .0022" to .0025" rods and .0025" to .0028" mains TBD
Balance the rotating assembly, weight should have to be removed for the TBD lighter bob weight TBD
Add another $100 in antifreeze and oil.
This doesn't include my time to assemble the motor, degree the cam and rebuild the carb.
Not for the faint of heart or light of wallet😱
Isn't that something like 50+ LS engines?
Yes, pretty close😳. I just can't do it, NO LS! Another new Challenger was almost purchased and the Cutlass sold, it was a serious consideration. My block should be ready and hopefully the crank is ground. The Mahle pistons hopefully are being made right away, then just balancing and assembly.
I bought one of last set of Accel 8.8 25 ohm race wires. Holley would not ship them to Canada, Cutlassefi got them from Holley for me, they were under $20 a set! I bought a set of these in the 150 degree? angle boots about 10 years back after the MSD 8.5 Superconductor plug wires cracked on the #1 plug wire. I do like the MSD crimper better than the Accel one. Geeh, I sure miss that hot running 403🙄. They have held up really well but it is time for new set for the new motor. These being straight boots, I made them a bit longer. They range from just under 50 ohms to 125 ohms per wire, extremely low resistance. The wire markers I bought separately, they work great.
I talked to the machine shop. Of course more work they had sitting that they had forgotten to do, have become priority🤔. Either way, pretty sure the block is done, was hoping to hear back this week that the crank was ground, I did not hear back. They gave a heads up on the Mahle pistons I have ordered, which hopefully is wrong. They have been waiting for parts from Mahle that keep getting the delivery date pushed back, we will see when they get done. The bad part, like every machine shop, the shop they use to balance cranks is two months behind. When I talk to them next week, I will try and glean what will be the quickest way to get my crank balanced. I will hopefully have bearing size known and order from them from Cutlassefi. I will contact him with the undersize and see if he knows where Mahle is at with their piston run. I am hoping to have the short block together before the end of August, otherwise Harvest could start and could go to November, it means possibly 6 days a week at work and no time to do this. No if I can find a way to have the kids pay for their cell phones and hopefully my oldest gets a good paying job, I could buy a second Challenger GT. Unlike trucks, which almost don't exist and even used are ridiculous, there is a nice White one sitting on the lot optioned how we want for 50 grand.
  • Sad
Reactions: JAMCAR223
Only $50k? Even with the exchange rate that's about 30 Pontiac Vibes. Granted, total HP/dollar is about even.
One tool I always use on my engines is a bore specific tapered piston ring compressor , once you have used one of these you will never use a universal ring compressor again.
