Re: Build Thread, What I've done so far
So it's been a pretty good spring break so far. I have my old exhaust off, the engine is running again (bad igniton module) my TV cable is hooked up correctly so my transmission should shift correctly now.
I'm working on the brake lines from the master cylinder to the prop valve... what a pain in the *ss... I can't get the fittings to thread into the valve
After those are done (sometime tomorrow), I'm gonna do the fuel line in hard line instead of the big rubber piece.
I'm going to give the car to a buddy to fab up the brackets for the crossmember, mount that, and install the exhaust. I think that will save me a ton of headache in the long run.
Also installed a new water pump gasket because the old one leaked.
