Oh and wide front tires are an issue with my headers because of that 1 header tube with the automatic everything cleared and fit nice but they are expensive headersdid the headers go around a the frame rail. Any fitment problems with them?
A lot of the small stuff that may be missing is the same in your 307I found another block that may be an option. fresh 72 455, standard bore recently honed, new cam bearings, crank bearings, and freeze plugs, claims its ready for pistons,also comes with a crank, stock 4bbl intake, stock starter, torque converter, and a new comp cam. asking $400 but told me to make him an offer. Also found a guy selling rebuilt j heads, ported, clearanced for high lift cam, machined for bigger valves, 80cc. I know j means junk but I heard they can be just as good with work done to them. asking price $600. Would probably pay up and get forged pistons and rods. What do you guys think of this option compared to the stock rebuild set up that has almost every thing everything there?
its not ready for pistons if it was just honed I'm positive if you brought it to a machine shop the cylinders would need to be bored out then finished honed to the new pistons if you add the two togather your close to the other engine that has had all that done with pistons already just remember you get what you pay for and with oldsmobile its always expensive so don't cut corners or you will have an engine that lasts 5000 miles like I posted previously buy that book, read it, then plan and execute it will save you money in the long runI found another block that may be an option. fresh 72 455, standard bore recently honed, new cam bearings, crank bearings, and freeze plugs, claims its ready for pistons,also comes with a crank, stock 4bbl intake, stock starter, torque converter, and a new comp cam. asking $400 but told me to make him an offer. Also found a guy selling rebuilt j heads, ported, clearanced for high lift cam, machined for bigger valves, 80cc. I know j means junk but I heard they can be just as good with work done to them. asking price $600. Would probably pay up and get forged pistons and rods. What do you guys think of this option compared to the stock rebuild set up that has almost every thing everything there?
the sbc I was going to put in the car only needed a hone freshen up the cylinder walls they were very good and still in spec. It really depends how nice the bores are. Do notice I said the seller claims its ready for pistons so I also have my doubts that it was good enough to just hone but who knows maybe it was.its not ready for pistons if it was just honed I'm positive if you brought it to a machine shop the cylinders would need to be bored out then finished honed
