I just ordered my Scat 496 stroker rotating assembly yesterday for my upcoming winter build. This is my first high performance build so im trying to do all my research to get the best possible setup when the time comes. Im on a budget and I dont need a 10 second car so aluminum heads are out of the question. My goals for this engine is a fun cruiser with hopefully 500-525hp. I dont have any experience with big blocks so im not sure if thats attainable with the build im planning. The specs im looking at right now are:
Cast 4.25" Scat stroker crank
4340 forged 6.385" H-beam rods
.060" over 18cc dome forged Probe pistons (should be between 9.7-10:1 CR depending on what the heads cc at)
122?cc open chamber 049 large oval castings
2.19" intake---1.88" exhaust valves
1.7:1 full roller Harland Sharp rockers
MSD 6AL distributor with the 6AL box
Still undecided on the cam but im looking at these two unless I get a custom grind from Lunati
http://www.summitracing.com/parts/ISK-396281/
http://www.summitracing.com/parts/HRS-121181-08/
I want a hydraulic flat tappet 108 LCA, the lift and duration im not decided on yet. My dad has always had great luck with Lunati so I wanted to go with them but they dont offer a hydraulic flat tappet with a 108 LCA for the BBC. I will use the lifters and springs that are recomended from the camshaft manufacturer.
I know this isnt everything I need but its a start. This will be a slower build until winter hits so I can actually get started. Any advice/info/opinions are welcome so feel free to tell me what you would and wouldnt do 😀
