Turbo on a stock GM TBI - you need an adapter for the 454 TBI TB for the SB TBI intake. The adapter is easy to find or fabricate, but the 454 TB is hard to find in good working order. A stock ECM will handle 3-5psi and function ok, sort of. But that's it. You need an engine management system as Supercharged mentioned.
For ease and expense, you should scrap the stock TBI plan. It's not big enough to handle 400hp without playing a lot of tuning games that are not entry level. Microsquirt, Megasquirt or Holley is what I recommend. I've been reading about MaxxECU that seems to work well for some. I've worked with the MS and Holley stuff - easie peasie. Of course you have the option of using a blow through as well which will eliminate the need for an intercooler in normal driving conditions. I have a work aquaintance that is blowing through a 650 Eddy with good success at 8-10psi. Very cheap and reasonable. Then you can use a stock dizzy and lock it out to 25 or so degrees and let the vacuum advance put in the last 10 degrees to 35 when out of boost.
Regarding a bolt on kit - unobtainium imho. I've bought two, both sucked balls and I had to cut the crap out of both and fabricate to make work. For low boost, stock manifolds will not hamper you and they are very durable.
How about some power goals. What I described above is an easy way to 400hp with 10 psi via a stock 250hp motor. It is great fun on the street, easily tuned and cheap.
