Re: 500 Caddy into El Camino
Darren I'm afraid I'm not much help on your question as fortunatly I don't have to deal withemmisions down here (if I did this project would probably never have been started as it will never pass an inspection (engine never available in the body and older than than the body). The best I could tell you would be to get ahold of an inspection station that will actually be doing the testing and see what they will pass. I do believe that a legal swap would be a complete setup form a newer model but I'm not 100% positive. Unfortunatly with the pretty primitive (by todays performance standards) emmissions on this generation of G Body your are pretty limited on making any real improvements.
"....all that 500 low comp cadillac engine is missing is a massive turbo and some injection....." :lol:
You have a point turbo 78, I guess I'm just an old fart that doesn't like change though
Now when I do rebuild this motor I am thinking about digging up a set of the big chamber heads and running flat top pistons... that would allow me to swap small chamber heads on and go from 8.2-8.5:1 compression to 12.5-13:1 compression with a head swap and use E85
