The transmission shifts fine driving around, but from a stop it takes more rpm than it used to to leave. it doesn't come out of gear and idle up (like it being put in park) like my other Th350 did when it was slipping, it just idles normally and slowly eases into the gear with throttle. And it won't hold itself on a hill anymore. even my slipping Th350, when it didn't pop out of gear, would hold itself.why do you think it's the TC?...have you checked the fluid pressure yet?
I got chastised on here for advising against changing the fluid in a high mileage 700R4. I agree with you, by the way. I learned the hard way.Never change the fluid, drop the pan change the filter put old fluid back in and top off.
If your changing the fluid it's because there is a problem and you "think" new fluid will fix it.
There is the new member that owns a transmission shop PM him maybe he will set you up with something.
It was windy. There were 2 or 3 dead leaves in there, I picked them out. The fluid sat open face in a garage over night, so the panty hose was used to strain any unwanted foreign matter before I poured it back into the transmission. Worked well. I did not haveyou had leaves in it? Tree leaves?
