Yup, I know. My big block in my 87 with aluminum heads, intake, even a FloKooler aluminum water pump
weighs 40 lbs less than the small block did. And [currently] makes more than twice the power. Gotta love that. I've just spent enough money lately. SBC Edelbrock Performer? $175-200. BBO? $350-400. Buying used is too unpredictable.
EDIT: BTW, I used those Permadryplus valve cover gaskets on my aluminum heads big block with the early 70s stamped Oldsmobile valve covers and have had zero issues. Believe it or not, with the Comp Cams roller rockers and the .496/.512 lift cam, I had a slight tick in a couple of spots and just needed the additional clearance the thicker gasket allowed. Problem solved. I have not tried them on iron heads though.
