7 blade fan
I have the Flex-a-lite 6719 aluminum 6 blade fan in my Regal with a 355 SBC along with a new thermal clutch and with a Champion aluminum radiator it runs 180 (thermostat temp) all of the time.
I stole my 7 blade from my 455 sqaurebody suburban.
It does well, HD clutch, new champion rad, all that fun stuff. Shame I can't use it tho with my setup. Too much weight hanging off the aluminum water pump the buick 350 uses.
I had been using a 7-blade stainless steel Hayden flex fan for many years. It really seemed to keep the engine running at a nice temperature. However, we all know flex fans are noisy as hell.
I'm now using a Hayden HD fan clutch and 7-blade Monte SS fan. I like it much better.
7 blade fan is a heavier rotating mass than needed and wasting hp. Cruising at highway speeds you should not need the fan and a 7 blade interferes too much with the air flow through the rad. We used a mechanical 4 blade on a G body circle track car and that car ran hot but never more than 240 degrees during the race. The car was chipped at 6200 and when running in traffice there wasn't much air coming through the rad but the 4 blade fan did it's job.
Yeah that 4 blade solid fan moves a lot of air. No issues on my 70S, never above 190 even without a shroud and a recored 2 core Copper Brass factory rad. One member fixed his 403's cooling issues with the 4 blade over the 307's 5 blade clutch fan.
Reactions: pontiacgp
Do you have the link for the blade?
I am curious as to why it has to be 7 blades when clearly there are other options with less blades.
