There's a few companies out there that make lock up kits. TCI, B&M, etc. You can also check out these guys, bowtieoverdrives.com.
i noticed your a sheriff i have a question since your a gearhead how do you go about on speeders and street racing when your on dutyJBreu said:I did this swap last year.....Shaft needs cut 3"...YOu weill nedd 49 1/2 " from center of U-Joint to Center of U-Joint. I had a column shift and scrapped that and put a b&M pro-stick on the floor, made things much easier. You will need a new crossmember or have yours modified. Most importantly you need to have the TV cable set properly. You will also need a new linkage bracket and geometry corrector. You can grab those at Jegs. You can also go non lock up comverter as well...
I'm not a fan of street racing, it's dangerous and illegal here in N.Y. As far as speeders, I use my discretion when I write tickets🙂79 drag car said:i noticed your a sheriff i have a question since your a gearhead how do you go about on speeders and street racing when your on dutyJBreu said:I did this swap last year.....Shaft needs cut 3"...YOu weill nedd 49 1/2 " from center of U-Joint to Center of U-Joint. I had a column shift and scrapped that and put a b&M pro-stick on the floor, made things much easier. You will need a new crossmember or have yours modified. Most importantly you need to have the TV cable set properly. You will also need a new linkage bracket and geometry corrector. You can grab those at Jegs. You can also go non lock up comverter as well...
