I didn't put a gauge on it but I can say if I unplugged anything it runs worseWhat's you manifold vacuum like?
I putzed with it all day instead of doing what I set out to do I couldn't leave it alone I just felt like I was going to get it and really didn't get anywhere I'm kinda hoping to get my brother over here when he gets back from the aaca show in Hershey PA maybe I can get him here sometime this week I must be missing something stupidThat's not too bad. I was thinking maybe that cam or a leak might be causing low vacuum. That could explain both the driveability and the late shift.
Glad to hear it's a runner. Too bad about the transmission.
When I gave him the transmission I gave him a b and m shift kit with it that I had here on the shelf I have no idea if he used it tho there's still plenty to do on the car so I'll just keep plugging on other stuff for nowDid the guy put a shift kit in it? Or say he was gonna do any "mods" to it? I've driven some cars with Th350s that were "built with a shift kit" and shifted at like 5500rpm at partial throttle. Banged super hard into gears, terrible. And all the kickdown cable does (kickdown in this case, Th200r4 and 700r4 use a TV cable) is control downshifting at full throttle. Adjusting it will do nothing. You can even unhook it, just will need to downshift manually. He f*cked up big time, but it's nothing that can't be fixed with time. Worse case scenario, you'll have to score a decent craigslist transmission.
16° at idle 17" at manifold vacuum advance is hooked up to the carb on correct port no vacuum untill off idle the radiator is a 3 core with oem shroud fan is 1970 442 455 5 blade with good clutchWhat you running for timing? Vacuum advance off manifold vacuum or ported? What radiator, fan, how many blade, clutch or no and is there a shroud?
