hey guys, I got the Best Gasket graphite impregnated rope seat for my400. According to the guys at Butler Performance, it`s the best one to use.
Dean
Dean
G-Body_Vet said:IROC steering box. A little FYI for those that don't know. The cast "Z" means absolutely nothing. The part number 2600525 doesn't either. I know for sure this box is 2.25 turns lock to lock. If you're on the hunt for one be sure to check it thoroughly. Here's more info for anyone interested http://www.thirdgen.org/techboard/suspe ... x-not.html
vet..I have a Z box in my GP and it does have the same ratio as a quick ratio G body box (12.7:1) but the internal stops make it a 2.25 box. Your U turns won't be as tight but in my case it stops the wheels from rubbing on my 36 mm bar. The Z does indeed mean something that you will notice when driving. The box gives you a heavier feel on the steering wheel and I'm sure you'll like it.
pontiacgp said:vet..I have a Z box in my GP and it does have the same ratio as a quick ratio G body box (12.7:1) but the internal stops make it a 2.25 box. Your U turns won't be as tight but in my case it stops the wheels from rubbing on my 36 mm bar. The Z does indeed mean something that you will notice when driving. The box gives you a heavier feel on the steering wheel and I'm sure you'll like it.
pontiacgp said:the larger u-turn is noticeable but it's not a drastic as some people suggest.....and a quick punch of the gas peddle shortens up a u-turn real quick.. 😀
deanlemans81 said:Thanks for the info and thread! I will study it to see what fits my lemans best. I`m basically looking for a similar to stock ride height or maybe an inch lower. I basically want to support the heavier weight of my 400.
Thanks, Dean
